3 Channel Amp
AllTheTimer
AllTheTimer Posts: 15
edited July 2004 in Electronics
I'm in the market for a sub-$500 3 channel amp to power a center speaker and a couple of surrounds. I've been searching on the internet for a store that sells them, but I haven't found any yet. I wonder if anyone knows where I could get one? Also, do you think I could find one with a subwoofer output and crossover, or is that generally reserved only for receivers? Thanks.
Post edited by AllTheTimer on
    VR3 Posts: 28,791
    edited July 2004
    Adcom GFA 5352 (or something like that)
    It has 60 watts x 3 or w/e...
  • AllTheTimer
    edited July 2004
    Thanks Vr, I'll have to check that out.
  • Danny Tse
    Danny Tse Posts: 5,206
    edited July 2004
    Depends on how efficient are your speakers and how big of a room you're trying to cover, J&R sells a 3 channel digital power amp from TEAC for $99.88. I believe it has 30 watts/channel. I got wind of this little amp from someone bi-amping his stereo speakers with these.
    TEAC A-L700P 3 channel power amp at J&R
    Check out the TEAC amp in action here.
    Here're the owner's opinions to the TEAC power amps.
  • steveinaz
    steveinaz Posts: 19,538
    edited July 2004
    Parasound used to make a 3-channel amp, don't know if they still do.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited July 2004
    I don't remember the model number of the most recent...think it was something like 1203...thinking 130WPC or so...
  • tonyv1
    tonyv1 Posts: 365
    edited July 2004
    Parasound doesn't make 3 channel amps any more.
    Here are the 3 channel amps they did make:
    HCA-2003A:
    220 watts RMS x 3, 20 Hz - 20 kHz, 8 ohms, all channels driven
    300 watts RMS x 3, 20 Hz - 20 kHz, 4 ohms, all channels driven
    HCA-1203A:
    140 x 3 watts per channel at 8 ohms
    200 x 3 watts per channel at 4 ohms
  • AllTheTimer
    edited July 2004
    Thanks for the suggestions.
    Depends on how efficient are your speakers.
    To tell you the truth, I only have the center speaker right now--an 8 ohm, dual 6" DCM. I got it mostly for looks, but it sounds okay. I'll probably get some cheap bookshelfs off ebay--maybe some Cerwin Vegas, or some R20's, for the rears. For the mains--not to keep on babbling here, or anything--I have AxiomM22's hooked up to a Yamaha AX592 integrated amp, with two PSW303's for the low end--I almost wish I had gotten the LSi7's, but it's too late now. The one thing I'm worried about with getting a 3 channel amp is if I'll be able to control the volume of all the speakers with my Yamaha remote. In the 592 manual, it says that if I hook up an external unit between the preout/main in terminals, then the Yamaha remote can be used for "overall adjustment of the sound level." Still not sure about that, though--a lot of this stuff is pretty confusing for me. I'm pretty much a rookie, if you hadn't guessed that by now.
  • Danny Tse
    edited July 2004
    This is what you need.....the Yamaha DSP-E492, although you will have to find it used.
    Just search ebay for completed auctions, one was sold for $87.00 less than 10 days ago.
    Otherwise, may be cheaper to get a new receiver.
  • AllTheTimer
    edited July 2004
    Thanks--appreciate that info. And 87 dollars? I can live with that.
