Pro-audio amps for home speakers??
I was just reading the post of the guys with the LSi15 and how he is powering it with a dj-amp. My orginal idea was to use my dvd player with a DD/DTS decoder built in and connect it to 3 stero amps. I did have a passive volume control between the dvd player and amp, so I can control the master volume. My only worry was that these DJ amps will not sound good. Here is the link to spec sheet. http://209.125.209.59/PDF/PT24-28.pdf To get 3 amps it will proably me cost more than to pick up a digital amplifier reciever, which I had hoped to do. The reciever route I gain convinece, and dts-es decoding (which no dvd player can do so far)
If I remember right, Pyle is known to have a higher noise floor than most other brands of pro amps. I would go for all the decoding and switching options a reasonable receiver offers for a home HT. Just get a model that has preamp outputs for all channels so you can always add great amps when you can afford it. Think upgrades.
DGHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Check out this MASSIVE thread I started on AVSForum that's getting a lot of attention. Get a good pro amp and don't look back. So far the Crown XLS-402A is making me cry
http://www.avsforum.com/avs-vb/showthread.php?threadid=418666 -
I hate to burst your bubble, but stepping up to just about any seperate amp from a receiver will put a smile on most folks face.
Nothin wrong with using pro audio amps at home- heres my personal experiences....
alot of the times the amp itself is noisy (not in the signal, but the actual amp). I have a Crown Macro-Tech 5000vz amp (5000 watts continuous bridged at 4 ohms) and the transformer is considerably noisy.
Also I have had problems with ground loops sometimes with the unbalanced connectors.
But it is hard to beat the value and power of a pro audio amp.-Eric
-Polk Audio -
Sounds good, I guess when later in August I pick up new speakers, ill go to some dj shop, pick up a pair of dj-amps, and compare them to my reciever. Ill see which suits me better. My only concern in I knwo with using amp, i can only get DD, DTS. I dont have enough money to buy amps and pre-amp. Thats why I was going to use the DD-DTS decoder in dvd player. But it sounds like going this route could be more problems. I guess ill stick to reciever with pre-amp out, and hopefully upgrade later. But everytime its time for upgrade i upgrade speakers and reciever, never just one.
I ran 2 Soundcraftsmen PM-840's for 15 years and loved them. They were the class "H" amplifier design and ran barely warm to the touch. Fantastic amps.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
so heres my question, the digital amp reciever I was going to get was going to cost me between 315-350 (depening on what model/brand) So If I were to buy 3 stero amps for around the same price (lets say 130 each) is it worth it, sound like most people say anything that pushes out a lot of power will be good.
Faheem , i don't think you will get much for $130..The Crowns' i use are around $270 shipped on ebay.Occassionally you may find them even cheaper.as far as the bang for the buck,It's a no brainer!!!! Never will use anything else but pro amps!! And yes, I believe I was the one who turned Mazeroth on to them!!
brickie
