Another question bout the polk c500.1
Systems
guys i know ive asked a lot of questions bout this amp already but i promise this'll be the last one...recently i asked about how to connect 2 subs to the c500.1 and the answer i got was the amp runs at 2ohm and the subs would be 250x2 now the problem is...is that still the case with a DVC subwoofer in particular the Bazooka P. MILLER Signature Series Dual 4 ohm 12 inch (RSW1224DVC-PM) http://www.bazooka.com/productAutoRawWoofersRS.asp?id=212
thiers a downloadable pdf file that gives more info. oh yea i wanna run two subs. thanx a lot guys
Testing
Testing
Testing
Testing
Testing
if they are dual 4 ohm coils...you would have to wire them at 4 ohms
i dont think the polk is capable of a 1 ohm load
does that mean i can hook up the subs at 4ohm and the amp at 2ohm so it would be 250x2 cause if thats the case im a
man Testing
Testing
Testing -
just wanna know is thier neway to hook up the system so i get 250x2 with the DVC subs cause the subs can handle 300rms so it wouldnt be fair to them if they only get 150 i was thinking wouldn't that be possible if i connect in series?Testing
Testing
Testing -
If you want to hook up 2, dual voice coil subs and get a 2 ohm load the only way to do it is to get one with dual 2 ohm coils and wire them in series. This will be a 4 ohm load per sub, hence 2 ohm total load and, voila, 250x2!
umm i think i understand but not fully..are you saying i can have my amp running at 2ohms in series and each DVC speaker will get 250 hence 250x2? sorry for being difficult just that im a starter
thanx a lotTesting
Testing
Testing -
arright you said i have to get one with dual 2 ohm coils what is the "one" are you talking about the wire please clarify
thank youTesting
Testing
Testing -
After giving it much thought i finally understand...can you please check the link on the origional message and tell me if those subs will be able to do 250x2 with the c500.1 thanks a lot guys and sorry for being a painTesting
Testing
Testing -
Can some one please check the above link and see if ill be able to do 250x2 with those subs and the c500.1 thanx guysTesting
Testing
Testing -
wire the voice coils in series and hook it up to the amp
that will give you a 2 ohm load and give you 500 watts to the sub
arright thanx a lot thats 500watts to both subs right?Testing
Testing
Testing -
no, 250 watts to each sub
