capicitor question
rodney
rodney Posts: 91
edited July 2004 in Car Audio & Electronics
the caps with the voltage monitor built on, is it reading the voltage of the cap, or the voltage of the battery?
alpine cda-9857
polk db6500
polk ex369
polk/momo mm104
profile ap1040
kenwood kac-7251
Post edited by rodney on
  • CPHILHOWER
    CPHILHOWER Posts: 343
    edited July 2004
    A 12v Test Light works just as well. And is Safer. Takes a little longer but you dont have to deal with the HOT Resistor. The Bulb is the Resistor. Can be used for Charging and Discharging caps.
    Chris
