My system
Systems
Systems Posts: 14,873
edited July 2004 in Car Subwoofer Talk
What do you guys think of this set up I have so far.
Panasonic CQDF 5834(Headunit)
Sirius Satellite Radio
Infinity Reference INI 6002I (Front Doors)
Alpine 6 x9 3 Way APN SPS690A
2 Polk/Momo MM2104
Polk/Momo C500.1
I'm planning on getting another amp for the internal speakers or maybe just for the Alpines because the Infinitys sounds real good with the head unit power.
P.S. How long does it take for an C.500.1 to break in.
Testing
Testing
Testing
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2004
    You may not like the Infinitys once you amp them up. I had a set running off deck power and they were fine. But once I stuck some juice to them they became way, way too bright and tinny sounding.
    Although, depending on what you listen to they may work just fine. Either way, I think its a good idea to amp the fronts.
  • beenthere
    beenthere Posts: 34
    edited July 2004
    I use a set of Infinity 6002si's in the rear door panels and Polk DB6750 components in the front. That combo works well in my car w/50W per channel. I personally did not find the Infinity's too bright for my use but I guess numerous folks here do. I'm only using them as rear fill.
  • exalted512
    exalted512 Posts: 10,735
    edited July 2004
    you dont have to break in the amp
    -Cody
