stupid computer question
gmorris
Please don't laugh at this one....
I'm playing around with this Windows Media Player thing, and have noticed a dilema.
On the WMP, there is a volume control. On the Master Volume control for the computer, there is "Master Volume" & "Wave". All 3 volume control can affect the volume.
So, my question? What is the best way to adjust the volume?
Also, the speakers DO NOT have their own volume control, they are passive.
Bob Mayo, on the keyboards. Bob Mayo.
Post edited by gmorris on
I always leave the wav full blast and adjust by the volume control... its all relative.. doesnt matter which you useMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Well, I went into the Properties for the Master Volume, and turned off Wave & Synth. Now, it just says Master Volume, but I still have the volume control on the Windows Media Player.
Strange.Bob Mayo, on the keyboards. Bob Mayo. -
all that does is turn off the view.. its still there.. you just cant adjust it..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Right. Out of sight, out of mind....
I've found that a very low Master Volume setting is best. Then using the volume on the Media Playa, that gives a very fine adjustment.
Conversely, setting the Master Volume very high, then trying to use the WMP volume results in blasting the sound no matter how careful I try to be with the control.
I guess I have to stick with a low Master Volume level.Bob Mayo, on the keyboards. Bob Mayo. -
Heh, it's even going to get more complex, as you will be able to adjust volume per application in the new "Longhorn" Windows.
I find that out of the 7 notches, I put them on the 6th or 5th, and then adjust the media player accordingly.LSi 9/C/FX
Arcam AVR-200
