2 subs and other thoughts
Hello everyone,
Well, after getting my first PSW505 fixed (loose wire), the vendor sent me a replacement PSW 505 which I elected to keep as a second sub. After reading all the articles on sub wiring and bass management...I have a couple of questions to help me create a more optimum HT system.
Room size = 23' length by 19' wide. listening distance to front speakers is 17'
I am using 4 RTi 6 (front and rear), CSi5 center, and two PSW505s located front left and right. Receiver is a Denon 1804 (wanted the 3805 and may still get it when I have more $$$ - but the 1804 works quite well). Subs are connected to LFE output using a y connector. All speakers are set to "small." I love the sound of the whole system. DVD sound is via optical out to the receiver. I'm very pleased with my choice of Polk speakers. I purchased the CSi5 because I wanted the absolute best center channel sound for movies. It seems to blend well with the RTi6s.
I'd like to reconnect the subs so I can more finely blend the bass with the rest of the system. I prefer keeping the subs in the front of the room. I primarily watch DVDs but also regularly listen to Sirius Satelite radio via my dish system.
From what I've read...it seems like the LFE out for subs is the least desirable method.
-- Would using the pre-outs (ie, tape monitor) (left to left sub and right to right sub), set sub to OFF, and speakers to large work better?
-- or, would you run the left and right channel speaker wiress through the subs (left to left, etc), sub set to OFF, and speakers to large.
Projection HD TV is next on the buy list.
thx! Mark
LSi9 + LSiC + LSiFx
dual PSW 505
Integra DHC 80.2 Pre-Amp
Outlaw 755 Amp
OPPO BDP-93 universal player
BENQ W6000 Projector
Da-Lite120 inch diag screen.
BlueJeans Cables all around.
Post edited by DesertPilot on
  • PolkThug
    PolkThug Posts: 7,532
    edited July 2004
    The best thing you can do is try it for yourself, and let us know your results. There are lots of opinions on this one.
    If you want more bass, try stacking the subs in the front left or right corner. Place some small pieces of rubber or other material on the feet of the top one to keep it from vibrating off. I think you'll be pleased.
    http://clubpolk.polkaudio.com/showcase/closeup.php?userid=51750&pic=91_21_big.jpg
    Setting the RTi6's to Large will make them sound muddier.
    Regards,
    PolkThug
  • scottvamp
    scottvamp Posts: 3,277
    edited July 2004
    Two 505's should rock, stack and use LFE. Many people use speaker line because they have HTIB systems.
    Sirus on satilite:confused: Provider?
    What TV are you using now?
    May be expecting to much from an entry level reciever?
    Welcome aboard!!!!
  • gidrah
    gidrah Posts: 3,050
    edited July 2004
    You might want to try one sub on LFE and the other on speaker level. Set to Sub = yes(rcvr xo as low as possible) and Mains= large. You might have to trial and error the settings as far as XO's and phase but it might work well.
    Make it Funky! :)
