Surrounds and Rear speaker question
MaC03
MaC03 Posts: 41
edited August 2004 in Speakers
I know someone just posted a similar question but my situation seems to be a bit different. So I hope you all don't mind me asking again. I'll be running the RTi8's in front and the CSi5 Center. My HT is in the basement and and is 16x22x7.5. The main seating will be about 12-16 feet back.
What I'm trying to decide is between the FXi3 and FXi5 as surrounds and either the RTi4's or RTi6's as rears in the 7.1. How important is it for me to mach the 8's 6 1/2 woofer all around with the FXi5 and RTi6? In that size room would those be overkill? Or is it just more important for the rear speakers to match in that situation. So in a sense grouping the FXi5 and RTi6 together and the FXi3 and the RTi4 together and then just deciding on one or the other? Or does that not even matter, as long as it's a combo out of those four?
Anyone have any of these combos? Any insite would be much appreciated.
Sony 57" WS HDTV
Denon 3805
Denon DVD-910
Monster Power HTS2600
Rti8 - Fronts
Csi5 - Center
Fxi3 - Surrounds
Rti4 - Rear Surrounds
SVS 20-39 Pci
  • fgr41
    fgr41 Posts: 432
    edited July 2004
    I would tend to agree. The most impoartant thing would be to make sure the surrounds and rears are from the same line of speakers, which is what you are going to do. Getting the larger driver will create a somewhat fuller sound but would it be really noticable over the smaller drivers, I doubt it. If you get a chance I would go with the larger drivers. If want to same some $ I would immagine the smaller ones would be very pleasing.
    Front
    Polk RT800i (BI-wired)
    Rear
    Polk RT600i
    Center
    Polk CS400i (BI-wired)
    Sub
    SVS 25-31PCi (22Hz tuning port)... it's SubHuman
    Receiver
    YAMAHA RX-V1400
    TV
    Mitsubishi WT-46807 HDTV
    HD receiver
    T i V o HR10-250
  • jam
    jam Posts: 3
    edited July 2004
    I posted a similar question ealier today... we kind of have the same setup:
    Fronts: RTi8
    Center: CSi5
    Surround: FXi3
    Sub: HSU STF-2
    Right now I only have a 5.1 system but want to upgrade to 7.1. Since I already have the FXi3 what should I get for the 2nd pair? Should the surround be FXis and the rear RTis? As you cal tell I'm very new to this and can use all the help you can give! Would another pair of FXi3 for the rear be the wrong choice?
    If I do end up getting a 2nd pair, the surrounds will have to be on stands next to the couch, see, my living room only has 3 walls, with one side sort of open to the kitchen, so I can only mount one surround to the side wall. Is this a bad idea?
    MaC03, how do you like your RTis? I just got mine calibrated today, (I think I did it right) and I'm very happy with the way everthing sounds! The H/K 630 really brought these speakers to life!
    Jamal
  • EricH
    EricH Posts: 140
    edited July 2004
    Go with the bigger speakers. I think you'll much prefer the lower frequency output, especially if you can set your surround crossover at 60 hz.
  • EricH
    EricH Posts: 140
    edited July 2004
    Jamal [/B][/QUOTE]
    Hey Jamal, I just got an AVR 630 last week. I love the ability to adjust my low frequency crossover settings. I'm running all of my speakers at 60hz and love the improvement over the previous 100hz setting. Where do you have your's crossed at?
    HK AVR 630
    RTi70 mains
    CSi40 center
    CSi30 surrounds
    RTi38 Rear surrounds
    Velo CHT-15 sub
  • jam
    jam Posts: 3
    edited July 2004
    Actually, I just hooked everything up this past weekend, so I haven't had the chance to make any adjustments. I set all the speakers to small. 60hz? Isn't that kinda low? I'll give it a try and see if it improves things even more!
    So, if I can't place the surrounds anywhere else, should I forget about 7.1? I can place them about 2 feet away from the couch, besides end tables, would the FXi3 work there? If not I'll have to look at mounting something in the ceiling!
    FXi3 for surrounds and RTi4 in the back, or FXi5 for surround nd RTi6 in the back? So, I should get the RTi4 since I already have the FXi3, or I should go bigger with RTi6?
    Thanks for the help!
    Jamal
  • up2youjoe
    up2youjoe Posts: 114
    edited July 2004
    Mac03,
    As long as you stick with the Polks I don't think you will be disappointed. Most of the sound comes out the front. You did not mention a subwoofer in your post. The Sub is THEE most important speaker in a home theater as far as I'm concerned. If you and your guests don't "feel" the movie, then you are missing something. Go with the less expensive rears and surrounds and spend the real money on the sub. ( just my opinion)
    No Kids Allowed
    cold, heartless, clueless, greedy 'young professional'
  • MaC03
    MaC03 Posts: 41
    edited August 2004
    Sorry for the late reply guys. Somehow I became "unsubscribed" to this post and didn't realize anyone had replied.
    I decided to go with the Fxi3 and Rti4's. I already have the 3's and the 4's will be coming soon. I love them! I'm really amazed at the quality of sound combining these with the my new Denon 3805. My HT room isn't finished yet so I've had to set them up in my current tv room which is the living room. I couldn't stand to let them just sit in the box. So I haven't calibrated them yet or anything, considering I have the 3's sitting on stools up against the wall.:) Needless to say, the wife is not a fan of this setup:rolleyes: I've got all the speakers set to small with the crossover at 80 and it sounds great. I agree with you up2youjoe which is why I got a SVS 20-39 Pci, and LOVE it.
    Jam, I love my 8's, I've been really impressed so far. The clear highs and mids are just a pleasure to listen to. I just can't wait to get it all set up correctly.
    Sony 57" WS HDTV
    Denon 3805
    Denon DVD-910
    Rti8 - Fronts
    Csi5 - Center
    Fxi3 - Surrounds
    SVS 20-39 Pci
