Ohm ?
hamzahsh
Which is better? I mean in terms of power quality and performance.
8 ohm, 4 ohm or 2 ohm
Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player)
NAD C272 (2-ch Amp)
Post edited by hamzahsh on
V=IR, P=IV, P=I^2*R, P=V^2/R. From these equations, we know a smaller resistance means more power to the speaker. In technical terms, there's less noise when hooking up a larger resistance, but the difference is so small no human would ever notice the difference.Brian Knauss
ex-Electrical Engineer for Polk -
Well it is easier to build an amp that has better quality, less distortion due to heat, and more properly designed cuircuts when dealing with higher resistance, but a higher voltage in direct opposition must be used to obtain the same wattage output. Therefore it is more stable to build a setup for 16ohm, but it's only appropriate in home use, bet even barely there. We're talking high Volts. Almost impossible in cars, without loads of cash.
Therefore a 8ohm is better and will have better cuircutry driving it inherently - and is seen in most home systems, but a 2ohm is easier for car use where 12v has to be stepped up to 40-70 V for the high outputs.___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself.
