Bi-amp CS40??
scornful
scornful Posts: 272
edited July 2004 in Speakers
I've been debating which amp(s) I would like to power my speakers. I think I'm prolly going with used from the gon. I've pretty much settled upon something with 200w/ch though. The thought occurred to me yesterday, why not 2 matching 5 channel amps (purchased one at the time) to take advantage of bi-amping my 150's and CS40 while the other 4 channels power my surrounds. Would it be a good idea to feed a CS40 400watts?? I listen to movies at around 0db ref on my 3802 (havent figured out how to set 0db though, so it's factory default). I listen to music LOUD, over 100db, all the time and think the power reserve would be a good idea. Or have I just drank too much beer this week?
Any opinions??
*Forgot to add - room is 14'x22'x8'
TV sits on one 14' wall, main listening/viewing spot is centered approx 16' from TV.
Denon 3802
B&K 7270
Outlaw ICBM
Behringer DSP1124P
Samson S1000
SVS 20-39CS+ (x2)
RTi150's
CSi40
FXi30's
RTi38's
Win Vista HTPC
InFocus 4805 ~100" Screen
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited July 2004
    You don't need an amp ... a few more months at 100+ dB consistantly and you won't be hearing much of anything.
  • scornful
    scornful Posts: 272
    edited July 2004
    lol the speakers are in the living room , I crank it and play video games in the other room, clean house etc.... It's nice being out in the country
    Denon 3802
    B&K 7270
    Outlaw ICBM
    Behringer DSP1124P
    Samson S1000
    SVS 20-39CS+ (x2)
    RTi150's
    CSi40
    FXi30's
    RTi38's
    Win Vista HTPC
  • organ
    organ Posts: 4,969
    edited July 2004
    You can use a good 2ch amp and bridge it to double the power. But if you're planning to bi-amp your entire system, two 5ch amps should be cheaper.
    Maurice
    VR3 Posts: 29,762
    edited July 2004
    I think you would be better off...
    Just adding ANOTHER center channel to it than bi-amping, 1 channel per center...
  • PolkWannabie
    edited July 2004
    Scornful ...
    I actually do use 2 - 5 channel amps ... in particular the Sunfire Cinema Grand Signature II's @ 425 wpc along with a 2 channel amp for the subs which I'm considering swapping out for another 5 channel as I could use a couple more lower power channels in the back.
    If you go this route give some serious consideration to using one amp for the speakers on the left and one for the speakers on the right as opposed to one for the fronts and one for the sides/rears so that the overall load on the individual amps is at least relatively balanced.
