Wall Mounting
landry_p2000
How high should the surround speakers be mounted above the listening position?
Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
I've been wondering on this myself. Will be getting FXi3's in the near future and due to the location of a large window, I might need to mount them as much as 5-6 feat above listening position. I'm hoping the Dipole effect will still work at this height.
All the product manuals I have say for normal surround speakers, they should be 2-3 feet above listening position.Dodd Audio ELP [ Tubes ] // Harman Kardon AVR330 // Parasound HCA-1203A // Denon DVD-2900
Polk Audio LSi9, LSiC, LSi 7 // HSU STF-2 // Signal Cable Interconnects (SG BW/A2/MP) -
Don't they make stands for the FX speakers? Why would they make stands for this type of speaker if they want you to wall mount them at least 3ft above listening position?Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD -
Send a post or PM to 'mantis'. He knows all about mounting options for the surround speakers. I mounted my FXi30s about 3 feet above the listening position and about 1-2 feet to the left and right of the couch on the rear wall. They sound excellent.
donahue -
I just picked up a clearance set of FXI30's at CC for $189/pr, so this is a timely topic. I was planning on mine being about 2 foot above the back of the couch and about 1 foot out from each end of the couch. I have a corner on one side of the couch, so the 1 foot distance from the end of the couch still leaves about 30" of space between the speaker and the corner.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
That sounds like my setup. I also have a corner at one side of the couch. I haven't tried this yet, but I have seen suggestions about switching the speakers from the way that Polk suggests mounting them. In other words, put the left speaker on the right and the right speaker on the left. This points the larger drivers at the listening positions and the tweeter on the other side away from the listening position. Anyone else tried this?
donahue -
I'm curious about this as well. Does anyone have an answer to this question?Originally posted by donahue
donahue [/B]Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
As far as the FXi3's & 5's are concerned there are tweeters on both faces of the cabs so it won't make any difference for them.
They do however only have one mid/woofer. For those having these speakers it's an easy enough experiment to swap them and give it a listen and it occured to me awhile back that this MIGHT be a viable option IF the surrounds needed to be placed in front of the listening area as opposed to the sides or behind the listening area where Polk recommends that they be placed.
