Niagara 5000
Geoff4rfc
in Electronics
Is anyone using one of these? Looking for feedback on those with experience.
Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
I had one in the past. Very good conditioner. Also needs a good power cable with it. I was using a Hurricane with mine.
I liked it so much I stepped up to the 7000 with a Dragon power cable.2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Signature 21 w/Hana Umami Red, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables -
Awesome!! Good to hear. What difference have you noticed between the 5000 and the 7000? I've been looking at the two and on the fence.......Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3 -
I have had my 5000 for over 5 years now, very very happy, 20amp Hurricane in from Furutech outlet into 20 amp dedicated. i went through the upgrade path to get there and once arrived at the 5000, realized it was the best for me and my system. made beautifully, holds plugs almost too strong! 90amp current reservoir !
I stopped with the 1200 model on a secondary system but if I felt a need to upgrade I would go with the 5000 instead of the 3000. Cost/benefit seems to be a better proposition with the 5000. The 7000 would be overkill for me and the cost jumped a lot since it was first introduced. Seems like those are harder to find too.
@Geoff4rfc , there is a bunch of similar discussion here: https://forum.polkaudio.com/discussion/201990/power-conditioner-recommendations/P1
That thread was unavailable over the last month due to fallout from the Jesse ban, but it is now back. -
1200 (or 1000 when I got it) was my first step out of the Monster Power bull crap realm
Got it and the cheapest Tornado PC I could get
It made a world of difference at the time with the Lsim towers -
I had used older model PS Audio AC regenerator units for a long time but found a benefit in switching to the Audioquest designs when using their power cables. The "using their power cables" on every component including a subwoofer approach did make a significant difference in lowering the noise floor in my case. I didn't think it would make as much difference at it did.
@Hermitism "AQ Niagara 5000: Best detail, best clarity, tightest bass, best impact and tonality, increased soundstage depth. One person thought it was more polite."
I swear this wasn't me, I didn't attend this event.
