Impedance graph or plot for a stock pair of Polk SDA SRS 1.2TL speakers
ptrooper
Hi everyone,
I am chasing a measured impedance graph or plot for a stock pair of Polk SDA SRS 1.2TL speakers.
I know that Polk's official literature never released a factory curve and only stated that they are "compatible with 8 ohm outputs". Because of that proprietary gap, I am trying to see if anyone in the community has personally pulled an actual measured curve across the 20Hz–20kHz spectrum using a Dayton DATS, WT3, or similar analyzer.
We are specifically looking to analyse the reactive current phase angles and the worst-case impedance dips. The goal is to calculate a parallel current-equalisation network to flatten out the load and mitigate the back-EMF reaction feedback acting on the driving amplifier.
Does anyone have a saved measurement plot or a link to an old thread where a member mapped out a stock unit?
Cheers!
Cheers!
VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable,
,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it!
