Cary SLP-05 Headphone Jack issue.
I was going through my closet full of audio goodies, and came across my OPPO PM-1 Headphones.
It’s been a couple years since I have played with them. Fired up the system, plugged them in, and the jack and or switch will not put it in headphone mode. Worked just fine last time I used them, no issues at all.
Any ideas before I call Cary next week? Part of me doesn’t care, because I rarely use it, but part of me likes knowing nothing is broken as well, especially for what I paid for it..
    F1nut Posts: 52,373
    Any other headphones you can try?
    Toolfan66 Posts: 18,408
    The headphones work fine in my OPPO 205, I am thinking it’s the headphone switch, I may take it out tomorrow, and polk my head inside..
    SCompRacer Posts: 9,374
    edited August 8
    I hear you, if it's there it should work.
    The switch/jack would have to be really dirty or bad for no sound at all. Powered off you could ohm test the switch. A pair of 6SN7 are used for headphone out, hard to believe they would both be bad. I don't see any relays in a nekkid underside pic. Cary has the schematics locked in a vault, nothing found with a quick search.
    We could blame you for knocking a wire off when you did the VU meter bulbs, but those are in the other chassis. :D
    treitz3 Posts: 20,342
    Cary is a pain point for me.
    Too many issues...with many things.
    edited August 9
    B) Hahahaha, fingered it out at this early morning hour. :D
    I forgot the amps need to be off, and they come on when you turn on the pre amp (remote triggers) pulled them, and fixed. LOL..
    It has been a while, guess I should have looked at the owners manual yesterday. LOL!!!
    Tom,
    I have only had the one issue with the meters, it was an easy fix, frustrating at first, but Steve at Cary walked me through it. I absolutely LOVE this unit.
    pitdogg2 Posts: 27,870
    Yep, rookie moment.. :D
    Have to say, OPPO made a great set of headphone's, they sound amazing, I had thought about selling them, think I will hang on to them now.
