iPad Pro problem
Dabutcher
Dabutcher Posts: 2,623
Anyone know how to get rid of this small keyboard? Seems like it appeared after last software update?
  • Emlyn
    Emlyn Posts: 4,886
    Easy. Place two fingers on the mini keyboard close together and move the fingers apart and you'll see the keyboard get larger until it pops back to regular size. It's usually called pinching and can be done in either direction to have a full size or small floating keyboard. On an iPad I use both my thumbs. The fingers don't have to be on the same hand for it to work.
  • Dabutcher
    You’re the best!
    So simple a cave man can do it!
    Thank you sir.
    You made my day.
    Love yours. D
