Anyone out there have spec sheet Db8
I just came across 4x 8" Db subs. Ild school/Original from late 90's. Looking for spec sheet so I can build a box and get these gems booming! Hoping someone out there has something. I contacted Polk and they didn't have anything for me.
Answers
    billbillw Posts: 8,166
    edited March 26
    I would try to use web.archive.org to find older websites that show the detailed specs (Crutchfield or Polk Audio?), but Google AI says they like sealed box with 0.25-0.35 cu-ft per driver.
    EDIT: Here, I saved you some time: https://web.archive.org/web/19970129170435/http://www2.polkaudio.com/db8.html
    Note, it looks like you have the 8ohm version.
  • Ganemz1
    Ganemz1 Posts: 2
    @billbillw Thank you SO much!!! Man you are amazing. I thought I'd searched everywhere. This is exactly what I was looking for. You DEF saved me some time. Greatly appreciated.
    Glad you came back around to see it. Good luck with the box build. Those old subs might not hit as hard as some of the newer stuff, but they should still sound great.
