Should I change speaker config in avr when removing sub woofer?
Moving houses and depending how on how much the subwoofer rattles the house I may to have to remove it. I currently have my speakers set to small and 80hz crossover?
(Es55 and es30) thanks
    treitz3 Posts: 20,366
    Yes.
    F1nut Posts: 52,406
  • NewToAudio
    NewToAudio Posts: 23
    Yes
    What should I change it to? Large?
    F1nut Posts: 52,406
  • skipshot12
    skipshot12 Posts: 2,171
    Yes.
    Large or Full range, whatever it's called on your particular receiver.
  • Emlyn
    Emlyn Posts: 4,920
    If the subwoofer is going to rattle the house the volume on it is probably turned up too high.
  • NewToAudio
    Emlyn wrote: »
    Would I need to rerun Audyssey every time I lower the volume? Was wondering about lowering the volume but didnt know if that point scraping it would be better
    billbillw Posts: 8,367
    NewToAudio wrote: »
    Emlyn wrote: »
    No, you don't need to run Audyssey every time. Audyssey almost always leaves the sub too hot. Use a separate sound meter and the manual test tones to verify that all the channels are within 1dB of each other after you run Audyssey. Change the level in the AVR, and leave the sub gain the same. That is, unless you are the max -dB for the LFE and it is still too loud. If that's the case, lower the sub gain, and rerun Audyssey. Then correct in the AVR.
