Are SRS MW6511's the same as CRS+ MW6511's?
While removing one of my 6511's from my SRS II's, I slipped with a screwdriver and poked a f(*&ing hole in the rubber surround. I found a similar vintage 6511 on eBay but it's marked CRS+ instead of SRS.
Would it be a direct replacement? Or should I have the surround repaired/replaced?
    Toolfan66 Posts: 18,369
    Buy the replacement, it is the same..
  • jmardy
    jmardy Posts: 27
    Thanks guys. I can't believe I did that. :s
    F1nut Posts: 52,305
    You're not the first and won't be the last.
    audioluvr Posts: 6,055
    In my youth I did this to one of my SDA drivers. I think I used Shoe Goo or rubber cement to repair it. Held up for years.
    Tony M Posts: 11,966
    My neighbor used bicycle tire innertube glue, and he said it worked fine on his B&W speaker surrounds. :#
  • jmardy
    jmardy Posts: 27
    Thanks guys. It's a tiny hole. I'll see what I can figure out.
