would an Outlaw RR2160 get the most out of a pair of polk R700's
i would be using the 60 hz hpf built into the amp. i wont be listening anything higher than 85-90 decibels around 7-9 feet away in a 15x14 room. would the amp generally get the best out of the R700's? im on a budget so pls dont tell me to just spend more money.
Answers
    billbillw Posts: 8,316
    It would probably sound pretty good. The Outlaw receiver is pretty well reviewed and has decent power into 4 ohms. For music, I'm sure it would sound better than any AVR in the same price range. The built-in DAC is OK, but you could definitely do better with a newer external DAC if you are primarily streaming digital music.
    VR3 Posts: 29,752
    would it compare to a biamped avr setup?
    too soon?
    >_>
  • bamsaker_287
    for context i am NOT using the mediocre DAC, using an onkyo c-7030 cd player as primary input. also a bit of radio as the outlaw is technically a reciever
  • jdjohn
    jdjohn Posts: 3,446
    I have an Outlaw RR2150 in my stable, and although I don't have experience with the Polk R700s, I think it would be a good match.
    Those Outlaw RR2150/2160 receivers/amps are very versatile, and have plenty of power. So personally, I would not hesitate to try one with those Polk speakers. Will it get "the most" out of the speakers? I have no idea. But, it would be a great place to start.
    To further my reply above, it will probably be a good match, but you have to be careful around here asking about how to "get the best" out of a set of speakers. It is possible those R700 and the RR2160 will produce the best sounding music you have heard in a home system, but there is always some other upgrade you can do, which, at a certain point, ends up being a lot of money spent on very diminishing returns.
  • Emlyn
    Emlyn Posts: 4,908
    edited February 2
    Not the best but it'll do the job within reason. 90dB is considered extremely loud and should be limited to short durations only. There is a big difference between 85dB and 90dB. 85dB is safe while 90dB isn't.
    With the reference to the high pass filter are you using a subwoofer? If so, what's the model? It would need to be at least as good at producing low frequencies as the R700s.
    The R600s may be a better choice from both a budget and in room performance perspective. I chose the R600s over the R700s for a smaller size room. They're also easier on the budget.
  • bamsaker_287
    Emlyn wrote: »
    Not the best but it'll do the job within reason." the r600 i measured considerable less flat and brighter sounding. im good. sub is vanguard caldera 10 subwoofer, its more than capable.
    So, a little digging finds that the Onkyo CD player uses a PCM1753 DAC chip internally. The Outlaw uses a PCM1792a, which is considered a step up, and a "Flagship" from TI/Burr-Brown, at least for that time (~2017).
    Don't be afraid to try the Outlaw with a digital coax from the Onkyo and see which sounds better to you.
