noob wanting a nice system for new car
Systems
Ok well i have a 99 acura 3.2tl and i want to put in a stereo system.
Bascially i listen to hiphop and want to have a good bass priced between 700-1400 dollars not including install.
any help you can give would help
Testing
Testing
Testing
Testing
Testing
what size speakers do you have?
how many subs do you want?
what size subs do you want?
A good "bump" system for under $1400? Well I can give you a pretty good one for a little more.
Start off with a set of Polk Audio MM6 for $300
Power them with this MTX Thunder502 for $300.
Then get this Diamond Audio M6 12D4 for $300. You can go with a multi sub set up for a bit more volume but I thought Id pitch something a little different. Impress your friends when you part their hair with only one sub!
To do that youll need this MTX Thunder801D for $500. Its rated at 800 but I bet it puts out more like 900 so youd need to be careful with the gain setting.
As I said thats a little over budget. Were up to $1400 without the head unit which should be another $300. The benefit to this setup is that it is all very high quality products that will serve you well and sound great. If you cant meet the budget then you should go to Crutchfield.com and check out Profile amps, which are great amps for the price. Polk DB speakers which are awesome for the price and Alpine or MTX subs which, again, are great for the price. You will be able to meet your budget a little easier with these but Ill guarantee ya it wont sound better.polkaudio sound quality competitor since 2005
