Ayuda emparejamiento de R700
Recién adquirí una pareja de Reserve R700, el amplificador que tengo actualmente es un Yamaha RN602A, quiero actualizar para obtener un mejor desempeño y estoy entre 2 opciones el Yamaha RN800A, NAD C389 (sin el módulo MDC2 BluOS D), la idea es obtener los mejor posible para no hacer cambios en un futuro cercano.
Alguien podría ayudarme con el tema? NO quiero causar daños ni en los parlantes ni en el amplificador.
Gracias por su ayuda
  • Emlyn
    Emlyn Posts: 4,920
    Either would be fine, but since the Yamaha RN-1000A is the same price as the NAD C389 I would also add that to the list. Any of them would be fine. Yamaha uses class AB amplifiers and NAD is using a Class D amplifier in the C389. I was just looking at the RN-1000A myself because it's been on sale.
    A general guide is to spend about the same on amplification as what is spent on the speakers.
  • JMILTONBS
    Gracias Emlyn, muy generosa respuesta. QUe tanta diferencia hat entre el YAMAHA RN-800A y el 1000?
  • Emlyn
    Emlyn Posts: 4,920
    They look very similar but the RN-1000A weighs a couple pounds more because of some internal component and construction quality improvements and the RN-1000A has an HDMI connector that the RN-800A doesn't have. The HDMI-ARC connector makes the RN-1000A easier to integrate with a TV in that you can control the TV's volume with the amplifier's remote control. The amplifier output specifications are the same.
    The RN-1000A has a five year warranty vs the RN-800A's two year warranty.
  • JMILTONBS
    Gracias
