SDA1C
I have a pair of these in great shape I would like to find a good receiver that would allow me to set up a subwoofer so that I can play these speakers while I play my drums and people can hear the music. Any recommendations on a reasonably priced receiver or receivers that I should look at.?
    VR3 Posts: 29,763
    These speakers are not meant to play with drums. Drums are like 120db, you will blow these up in no time
    billbillw Posts: 8,371
    edited November 2025
    I think he means that he will play drums with backing music, but it is a bit unclear what is intentions are. @Ocdrumbum , can you clarify?
    Regardless, you might not need a subwoofer with those 1C if everything is working correctly and they are fed clean power. If you need a sub, any AV receiver in the last 20 years should have a subwoofer output and bass management settings.
    Just find one with good power output for the 1C. If you don't need HDMI input/output, find an old Onkyo SR805. That has gobs of clean power (but bad HDMI boards). Bad HDMI won't affect sound from an analog or digital optical/coax input.
  • Ocdrumbum
    I meant backing music while I play. I have friends who want to watch me play but also want to hear the tunes I’m playing. I use cds and headphones for myself.
    While I play. I currently have a Carver amp and pre-amp
