ES15s better wall mounted or with a stand?
Trying to work with a budget and before dropping any money Id like to ask this here
Has anyone tested this model out both against a wall vs stands? Wall mounted route seems a lot cheaper since its just needed one screw per speaker
    F1nut Posts: 52,406
    Tweeters should be at ear height. Generally, that is better accomplished with stands.
  • NewToAudio
    NewToAudio Posts: 23
    I am able to get them ear height on my wall easily
    mhardy6647 Posts: 35,562
    edited June 2025
    I would expect them a priori to sound better (more spacious and more transparent) away from the back wall (and side walls, too, actually).
    Zero experience with the ES15, but there is a pair of the earlier and slightly larger S20 here (courtesy of a generous and thoughtful Polk Forums denizen). Never tried them up against the wall*, but they sound pretty good well out in the room. A little heavy-sounding, but quite pleasant top to bottom.
    A pair of Altec Santiagos serve as good loudspeaker stands to get the tweeters to ear level. B)
    ____________
    * For some reason, a lyric from the Jefferson Airplane song Volunteers just started playing in my head. :#:blush:;)
    F1nut Posts: 52,406
    You might want to think twice about wall mounting those speakers.
    https://forum.polkaudio.com/discussion/177041/keep-these-s15-speaker-mounts
  • NewToAudio
    Just got them on the wall yesterday afternoon. Looks pretty good and I’ll have to keep an eye on them. Probably will get stands here soon when I can budget it. I couldn't use big ole kitchen chairs forever lol
    heiney9 Posts: 25,714
    They will sound better on stands, properly set-up for your listening space.
