Tidal w chrome cast
EndersShadow
EndersShadow Posts: 17,763
edited April 2025 in Going Digital
Hey everyone!
I’m wanting to get some opinions on my current office setup and suggestions for an inexpensive DAC.
Right now my setup is this:
IPad running Tidal —> Apple Camera Connector —> iFi purifier —> iFi Zen DAC —> Parasound zpre 2 —> PreSonus 8” sub —> PreSonus zeros 3.5
For cables I’m running:
1. Wireworld Ultraviolet USB-B (Camera connector —> iPurifier)
2. Wireworld Solstic 8 RCA (Zen —> zpre)
3. MIT EXP2 (zpre —> Presonus sub)
4. Audioquest Component cable (Sub —> speakers)
So while this setup works just fine, and I’ve got no complaints in sound, it’s a decent amount of cables on my desk and I’m wondering if I can consolidate it down and eliminate the hardwire connection from my iPad in favor of wireless without spending a ton.
I’ve got a Chromecast Audio which I believe I can cast Tidal to from my iPad but the zpre doesn’t have an optical input nor does the Zen.
I’m curious if anyone has experience running a Tidal through the Chromecasts stock DAC and/or what a good INEXPENSIVE used dac with optical, USB, and maybe coaxial (so Ive got all the connection options) might be.
Thinking under say 125 only because I have a working setup already so I don’t want to spend a ton more. Prefer something small (I.e. not 17” wide) but can’t be too picky.
Appreciate your thoughts.
Couple quick notes:
1. I’m trying to shore up the backend up to the zpre as eventually I will be getting better speakers in the office.
2. I’m fine adding in some sort of optical to usb adapter of good quality so I can keep using the Zen
3. I’m aware of the WiiM stuff (Pro, Pro Plus, Ultra) as I bought a WiiM Pro Plus for my downstairs setup and it’s an option but looking to see what else might be out there
  • Geoff4rfc
    Geoff4rfc Posts: 3,062
    @EndersShadow it appears Dan, that not a single person has the experience you're looking for. I wish I could help!
    By the way, don't see enough of you man!!
    Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
