ferro fluid in Peerless tweeter?
Anyone know whether or not the early (1978) Danish Peerless tweeters (KO10DT?) contained ferro fluid?
I have searched the forum, but find only conflicting or ambiguous information.
    VR3 Posts: 29,763
    Pop the top and take a look
  • Astrl55
    Astrl55 Posts: 68
    VR3 wrote: »
    Something I might consider if I had one here.
    mhardy6647 Posts: 35,562
    I don't think so.
  • Gardenstater
    Gardenstater Posts: 4,991
    Nope on Danish or USA made ones. If you were to open one up just to look you could lose the voice coil positioning.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    VR3 Posts: 29,763
    I have never experienced that with a tweeter with a removable faceplate? There are usually tabs that position the voice coil? With an inner frame
    Is the peerless different
  • Gardenstater
    In the Peerless the dome/voice coil are glued to the faceplate and there are 4 oversized screw holes that allow centering of the voice coil in the magnet assembly. No tabs. No alignment pins or anything.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    VR3 Posts: 29,763
    Interesting.
    I hope it doesn't use ferro fluid then 😬
  • Gardenstater
    No ferrofluid in the Peerless.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Astrl55
    Astrl55 Posts: 68
    Thanks Gardenstater
