Tire shops
  • Jstas
    Jstas Posts: 15,001
    Willow wrote: »
    I see this thread is still rolling on. I'm no tire expert, nor do I claim to be one or have ever played one on tv, but I think this thread needs to be rebalanced.
    Static or dynamic?
    Road force.
    Expert Moron Extraordinaire
  • motorstereo
    motorstereo Posts: 2,412
    I've been changing tires and wheels ever since I was old enough to break a lug nut. I can't recall ever once using a torque wrench or seeing one used on a passenger vehicle or truck. In my later years I worked in my employer's garage where they kept and worked on their 3 modified race cars. I also can't recall even once where a torque wrench was used on those wheels either. I also never used or saw a torque wrench used on tri-axle and heavy equipment wheels either. I guess I should count my blessing that I've never lost a wheel or crossthreaded a stud. Yes I always started them by hand first when using an impact.
  • Gardenstater
    Gardenstater Posts: 4,881
    edited April 2025
    I ALWAYS torque mine. Had a nightmare once where I had a Firestone do my tires and shortly after got a flat late at night and couldn't get the lug nut off because the clowns had overtightened them with an air impact and no torsion bar. I had to get someone to bring some fix a flat to me and drove it the next morning and they had to remove the stud and press a new one in because they couldn't get it off either, that's how badly galled/seized it was. Since then I've always been adamant with any tire place that they have to use a torque wrench. Also, I put anti seize on my studs even though many will say that could result in the nut being tightened too much based upon normal torque spec..
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • sucks2beme
    sucks2beme Posts: 5,701
    I don't normally use a torque wrench for tires either. I don't even mind the whole
    Impact to tighten thing. It's the running them in cockeyed. When you have to break
    them off to remove the rim, that's an issue. I've driven home with three lugs holding
    On the tire a couple of times. I decided to pull all the tires off once after getting home.
    All 5 on the other front tire were cross threaded. Yes, I broke off all 5. I was so mad
    I'm sure the neighbors were concerned. Lots of bad language. My son had the same
    Issue with those clowns at NTB.
    pitdogg2 Posts: 27,767
    As long as they don't sit there and hammer away after tight with the impact you should be fine.
    Once again as long as they start them with fingers first.
  • daddyjt
    daddyjt Posts: 3,213
    It’s crazy to me what a huge conversation this turned in to. A quick hit with an impact gun, good tightening with a hand wrench or a precise torquing - just get them good and tight. Start the threads by hand, don’t over tighten, and do the star pattern to avoid warping…
    ― Aleksandr Solzhenitsyn
    treitz3 Posts: 20,275
    Nuts matter.
  • PSOVLSK
    PSOVLSK Posts: 5,433
    daddyjt wrote: »
    My granddad had a full service gas station when I was growing up. At around the age of 10, I started “working” there. My uncle showed me basically what you described above and I often put tires back on cars after fixing a flat, getting new tires, etc. I was, of course, highly supervised, but I was able to do it at 10 years old.
    Meanwhile, in today's world...
    My son is taking College level classes (he isn't even going to his regular school) and he can't find a job at 15.5 years old.
    My, how the world has turned...
