which speakers should I keep: Polk Monitor 10s or Monitor 7s?
I have too many speakers and need to downsize. My main speakers are Polk SDA 2B TL and those are my keeper speakers.
Among my other speakers, I also I have two pair of Polk Monitor 10s and a pair of Polk Monitor 7s. They all have the excellent Peerless tweeters.
My question to my fellow Polkies is the following:
What pair of speakers would you keep (any why) if you could keep only one pair: the Monitor 10 speakers or the Monitor 7 speakers?
I mainly listen to jazz and rock, on both vinyl and CD. I like all types of jazz, everything from Miles to Sun Ra. And I listen mainly to classic 60s and 70s rock (I am a big Grateful Dead fan and listen to a lot of live GD shows).
Thanks.
  • Conradicles
    Conradicles Posts: 6,437
    I would keep both if you could!
  • drop1
    drop1 Posts: 92
    Does the Monitor Series - peerless tweeter stand up to the RD0198 in your SDA 2bTL?
    F1nut Posts: 52,406
    Monitor 7 because it is nicely balanced, doesn't have the inherent issue of the 10 and flat out sounds better.
  • pglbook
    pglbook Posts: 2,267
    Thanks, Jesse. I appreciate it.
    What is the inherent issue of the 10? Is it a phase issue?
    pitdogg2 Posts: 27,921
    pglbook wrote: »
    Comb filtering from the side by side driver sending the same signal....
    My guess.
  • pglbook
    pglbook wrote: »
    My guess.
    Thanks!
    F1nut Posts: 52,406
    Yep, that's the inherent issue.
  • lms
    lms Posts: 54
    I had 10's, upgraded them, TL mod, etc. and loved them for over a year. I then went and listened to some crs's, sold the 10's toot sweet. I then went and listened to some 7,'s, sounded great, but I love crs's so much that I sold all my other speakers.
  • pglbook
    Thanks again, Jesse.
    Thanks, lms.
    mhardy6647 Posts: 35,562
    Concur vis-a-vis the Monitor 7 as being the choice.
    That said, keeping both is an excellent Plan B.
    B)
  • boston1450
    boston1450 Posts: 7,759
    7's
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • pglbook
    edited April 2025
    Thanks for the input, everyone!
    Looks like the Monitor 7s are the consensus favorite!
  • joebass3
    joebass3 Posts: 311
    You have the 10's and 7's so which do YOU like best? I know I'm the odd man out here but I also have both and my 10's are definitely my favorite!
  • lawdogg
    lawdogg Posts: 472
    edited April 2025
    I like 10s better. Comb filtering (and iirc also called "lobing") doesn't matter when I'm sitting still. I also listen to them on their sides ... But you should keep whichever one you like better!
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • Gardenstater
    Gardenstater Posts: 4,991
    There's even a form of comb filtering with a single driver......oh unless you've installed Rob's (xschop's) phase plugs that is. 😁
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Gardenstater
    edited April 2025
    Stu Lumsden said he prefers the 10 over the 7; lots more bass but a bit warmer.
    Correction of what I wrote previously:
    But he said his favorite is a pair of 7s stacked head to head; excellent dynamic range and not as much boom but arguably more accurate bass. Maybe with a sub for the bottom octave.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
