Not happy with new banana connectors
Yesterday I decided to pick up 2 pair banana plugs. I bought the crimpless 24k AR bananas. I cut the existing bare wire and re-stripped to start fresh. Set them up, tightened all and hooked them up into the receiver. Ok not bad......
Then I turn on my receiver and noticed immediately a hollow sound with voices and an overall very tinny, non dynamic sound...so I pulled out the receiver and checked connections...everything was tight and polarity was correct..
Before I yank these things out, is there anything that I did wrong?
AR says you can use these w/ 16 to 10 guage speaker wire; I am currently using 16 guage (with the intent on buying 12 guage next week). Plugs are tight and hooked up correctly...
What is causing this "hollow" sound....
Thanks in advance
Mike
My current modest lineup
H/K AVR 225
Fronts: Polk R30
Rears: Polk R20
Center: on the way
Sub: on the way
Thanks in advance
Mike
H/K AVR 225
Fronts: Polk R30
Rears: Polk R20
Center: on the way
Sub: on the way
Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29
Mains: polk R30
Center: polk CSi3
Sure sound like a phasing issue...but if you're sure its not:
The banana is not causing this problem. 16awg, while "acceptable" is not really ideal. Try either a heavier gauge of stranded (at least 14awg), or try a solid-core copper wire. Radio Shacks 18awg hookup wire works well and is dirt cheap. Take 2 strands (leave the insulation on) of the RS wire and wrap them together. Strip the last 1" inch. You can also triple up or even quadruple the wires and twist together. Of course solid core and twist banana's don't always work well together.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
I actually had good sound (surprisingly) with the 16 guage and when I hooked up the bananas I noticed a big (turn for the worse) difference.
When I get home from work, I will retrace the wire and double check polarity. Of all else being equal, this must be the problem
The store I bought the connectors from also have 12guage AR pro series wire 30 foot roll for $29.99. What do you think about this wire?
I will also stop at RS to check out the 18g wire you recommend. I never thought about stranding 18g together.:D
Thanks for the tip
MikeReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
DVD: Panasonic DVD-S29 -
I would also take the Banana plugs back out, and check the sound with just the bare wire connected. Then, re-install the 'nana plugs. You want to be sure that the plugs are causing the problem.
Having said that, I have to agree with Steve & say that the problem is probably not the plugs.Bob Mayo, on the keyboards. Bob Mayo. -
Mike-
It could be the connectores then. Thats strange, I wouldn't think a banana connector (even a cheesey one) would cause that much difference....Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Well after I got home from work I checked everything. All seemed well.....So I yanked the bananas out re-connected the bare wire the way I had it and turned the unit back on and ...perfect.
The only thing that I can think of is that the 16g wire, although AR says you can use 16-10g wire, is too small and is not yielding a good connection. I repacked the bananas and will try again when I get better wire.Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
