C500.1 and MM120
Sisouphanh
I have 2 MM120's and 2 C500.1's I was wondering if I have to bridge them like a regular amp or if "sub 1" output was internally bridged already... the instructions say nothing about bridging... thanks.
Post edited by Sisouphanh on
The outputs are just in parallel and cannot be bridged. The second output is basically there so you can hook up two 4 ohm subwoofers and create a 2 ohm load as seen by the amp. Just use the sub 1 output on each amp to drive one MM12 (ie one amp per sub)Brian Knauss
ex-Electrical Engineer for Polk
