help
Systems
Systems Posts: 14,873
edited July 2004 in Car Audio & Electronics
i have a c300.2 carbon series amp
is it two ohm stable ?
or do i have to run only 4 ohm
thanks..
Testing
Testing
Testing
  • denis87
    denis87 Posts: 86
    edited June 2004
    the specs on the website say 220x2 at 2 ohms so yes it's 2ohm stable.
    www.dmbvideo.com www.oilfans.com
  • exalted512
    exalted512 Posts: 10,735
    edited July 2004
    ONLY IN STEREO
    another words, if youre running 2 ohm components--one from each channel--then youre ok
    if you connect the 2 channels then no...youll fry the amp
    -Cody
