Polk MOMO MM12s : 2 Ohm Safe?
djenkins_2k
djenkins_2k Posts: 10
edited July 2004 in Car Subwoofer Talk
Hello everyone. I have 2 Polk Momo MM12's and am in the process of buying a more powerful amp. They're spec sheet only list them as 4ohm and I would like to bridge a 2 channel or mono amp to push both subs at around4-500 watts @ 2 ohms.
Any and all help is appreciated.
Also, if anyone if looking for a great amp, I'm selling mine on eBay right now:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5707393609&ssPageName=STRK:MESE:IT
Polk db6500 [front]
Polk db650 [rear]
Polk MOMO MM12 [2]
PolkAudio RT600i [front]
PolkAudio CS245i
PolkAudio F/X300i [surround]
Post edited by djenkins_2k on
  • exalted512
    exalted512 Posts: 10,735
    edited June 2004
    yea, you can run them at 2 ohms
    -Cody
  • Systems
    Systems Posts: 14,873
    edited July 2004
    U have to make sure that if you bridge your amp wont make it 4ohms. that is what most 2 channel amps do. Also check if is mono it may be class D one channel with two connectors.
    Testing
    Testing
    Testing
  • djenkins_2k
    edited July 2004
    Thanks guys. After reading a review in Car Audio & Electronics magazine, I decided to take a chance on Lanzar. I went with the 1800D rated (and proved to deliver) 1875 watts @ 1 OHM.
    I have it running 800 watts x 1 @ 2 ohms for my MM12s. I recommend this amp to anyone.
    Polk db6500 [front]
    Polk db650 [rear]
    Polk MOMO MM12 [2]
    PolkAudio CS245i
