SDA 2's 1984 Original Condition
So it's December 2024 and I am running 1984 original SDA 2's. I have heard there were some upgrade/enhancement kits for these available in the past. Can anyone comment on these kits - like what did they do and what did they consist of? Are they still available, where, how?
Best Answers
    F1nut Posts: 52,382
    Answer ✓
    These then...
    F1nut Posts: 52,382
    Answer ✓
    Well yes, Polk still sells some replacement parts in the form of upgraded tweeters, but modifications are on you. Like I stated, plenty of info here, so get your search on. B)
Answers
    F1nut Posts: 52,382
    edited December 2024
    There are no kits, but there are upgrades. Plenty of info here, just get your search on.
    BTW, there are a number of SDA 2 models, such as the SDA II, SDA 2A, SDA 2B, so it would be helpful for you to know exactly which model you have.
    pitdogg2 Posts: 27,883
    As well as SDA SRS 2
  • la2vegas
    la2vegas Posts: 772
    Although I believe that this model was released in 1986 and the OP states that his speakers are from 1984.
    Gee look at the time......
  • SparkyMF
    They are 1984 SDA 2 (no suffix)
  • SparkyMF
    Yes, those are the ones. Polk will sell new tweeters for $60 ea but no mods
