Help with L800
Just brought home L800 with an issue.
Picked them up today and checked them out before buying, determined the SDA side of the left speaker isn't working. No sound at all. The right speaker functions properly
I was told the left speaker binding post was broken off when being moved. All the binding post were replaced on the left speaker.
I can't look at it now. I have to wait until my sons come over on Tuesday to get them out of the car.
Need help with what to check.
If the left speaker is not connected to the amp and the SDA cable is attached, will it receive sound out of the SDA side? Trying to determine if its the binding post or if the SDA side is hooked directly to where the SDA cable attaches.
Hopefully, it's something easy!
