Subs
Systems
Systems Posts: 14,872
edited July 2004 in Car Subwoofer Talk
Whats Polks Best SPL Sub?
Testing
Testing
Testing
  • exalted512
    exalted512 Posts: 10,734
    edited June 2004
    the mm12 is the loudest...i wouldnt consider it an SPL sub though...
    -Cody
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    edited June 2004
    Polk and SPL? Thats like yugo and car...just cant be in the same sentence :D
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2004
    Right. Polk Audio is a sound quality speaker manufactuer. I wouldnt consider any of their products to be geared toward SPL. SQ speakers are built entirely different than one made for SPL. That doesnt mean that Polk speakers cant put out some DB or that SPL speakers dont sound good, just that youd be better served by looking into speakers built for that arena.
    If thats what youre after you should look into Kicker, MTX, Rockford Fosgate, Crossfire and the best SPL sub, the Orion H2. Of course its pricey but its king of the DB drag.
  • Systems
    edited June 2004
    Buy 20 mm12's and get 10,000watts
    tada
    Testing
    Testing
    Testing
  • Airplay355
    Airplay355 Posts: 4,298
    edited July 2004
    u forgot to add a really big battery to that list
  • beenthere
    beenthere Posts: 34
    edited July 2004
    And perhaps a 20,000 amp alternator...
