Polk L800 SDA with Musical Fidelity M8xi
Hello fellow Polkies... I am purchasing a pair of L800 SDA speakers with the intention of powering them using my Musical Fidelity M8xi Integrated Amplifier. My research indicates that this amplifier is a true dual mono, bridged unit. My understanding is that I cannot operate the SDAs as designed without using a "dread knot" type of setup. I'm looking for confirmation and/or recommendations on this combination. I have other amplifiers that I could utilize, however, I was really wanting to use the M8xi. I'm currently running LSiM 707s in 2-channel with this amp, and was hoping to upgrade to the L800s to gain the coveted SDA technology in my listening environment. Thanks in advance for your support!
    nooshinjohn Posts: 26,058
    You will be just fine. Balanced differential amplification causes issue with the Legends. Mono amps are just fine
  • You will be just fine. Balanced differential amplification causes issue with the Legends. Mono amps are just fine
    Thank you for your quick feedback, I appreciate the confirmation. Cheers!
    F1nut Posts: 52,136
    westtn wrote: »
    You should check with MF first.
    BTW, you cannot use an isolation transformer such as the Dreadnought with the L800 speakers.
  • F1nut wrote: »
    westtn wrote: »
    Thanks for the feedback. I have a note into MF and posted on their forum. Great to know Dreadnought isn’t an option for the L800s. Appreciate your help!
