Marantz SA-10
Does anyone own or have experience with the Marantz SA-10? I currently am using an Oppo 205 and really have no complaints with it but have the urge to upgrade and I have never had a disc player at the level of the Marantz. If I get it I will continue to use the Oppo for surround discs which I enjoy. My system is all digital- no turntable and no interest in getting one. I will also be adding a dedicated streamer in the near future.
I see Accessories for less has the Marantz at a decent price but still very expensive. Should I be concerned with going with a refurb unit on a disc player?
I’m currently using a Marantz SR 8012 with a Parasound A21+ driving the front 2 channels, L800 mains, L400 center, LSi702’s for surround, and PSA 2112 sub. I will move to a dedicated processor and additional amplification in the next year or two.
Any input or comments will be appreciated.
Steve
    F1nut Posts: 52,406
    I've heard it, stellar.
    Check the Steve Hoffman forum, lots of discussion about it there.
  • simm
    simm Posts: 605
    I’ve read those posts and that is really what got me interested in it. Would you be concerned about buying a refurb unit? I’ve always bought new disc players.
    F1nut Posts: 52,406
    No worries about Accessories4less.
  • Emlyn
    Emlyn Posts: 4,920
    Music Direct still has one new in the champagne finish for $4995, and an open box one in the black finish for a bit less:
    https://www.musicdirect.com/disc-player/marantz-sa-10-sacd-cd-player/
  • simm
    simm Posts: 605
    Emlyn wrote: »
    Thanks, I saw those. I do prefer the black. I just need to convince myself that the use would justify the cost.
  • simm
    simm Posts: 605
    treitz3 Posts: 20,366
    Would you possibly be interested in my Marantz SA-7S1 Reference CD/SACD player? Right now, it's just sitting in my closet.
  • simm
    simm Posts: 605
    treitz3 wrote: »
    I’m not familiar with that player. Will need to do some reading but think it might be older than what I want to go with.
  • simm
    simm Posts: 605
    After a couple of weeks of dragging my feet I missed out on the deals on the SA-10 right after the holidays. I kept trying to convince myself I still listened to my physical discs enough to spend SA-10 money. After doing some some honest evaluation on my system and how I listened to music now I decided I wanted a nice CD/SACD player as well as a quality streaming setup. With that said I was able to pick up a mint Luxman D-05u disc player locally that I am enjoying immensely. Over the next few months I will be adding a dedicated preamp and streamer.
  • mpitogo
    mpitogo Posts: 523
    I have both the SA-10 and PM-10 since 2019. It’s a great disc player but it’s also a great DAC. I’ll give everything up before I
    I give up the Marantz. And also for the size of the Totem Hawk, I haven’t heard anything that can compete except if it cheats like the B&W Formation in my office. The combination is the purest of my systems.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • haudevbe
    haudevbe Posts: 17
    The Marantz SA-10 is a serious upgrade if you're looking for top-tier 2-channel digital playback. It’s built from the ground up as a reference-level SACD/CD player and DAC, with a heavy focus on extracting the most detail, warmth, and realism from discs.
    How It Compares to the Oppo 205:
    Your Oppo UDP-205 is already an excellent universal player, especially for multi-channel and video. However, for pure 2-channel audio, the SA-10 will bring:
    ✅ Superior DAC & Filtering: Uses Marantz's custom MMM (Marantz Musical Mastering) DAC, which upconverts everything to DSD before conversion—potentially leading to a smoother, more analog-like sound.
    ✅ High-End CD & SACD Playback: The proprietary disc transport is better optimized for music than the Oppo's universal transport.
    ✅ More Refined Analog Stage: Better internal power supply and circuitry mean lower noise and improved microdynamics.
    Concerns About Buying Refurbished?
    Accessories4Less is reputable and Marantz refurbs typically include a warranty.
    Disc players have moving parts, so check the return policy just in case of any mechanical issues.
    If it saves you a significant amount over new, it’s probably worth the risk, especially since high-end Marantz gear is built to last.
    Does It Fit Your System?
    Your Marantz SR8012 + Parasound A21+ setup will absolutely benefit from a higher-end source like the SA-10.
    Since you’re moving to a dedicated processor and more amplification, the SA-10 will likely scale even better in a cleaner signal chain.
    If you’re adding a dedicated streamer, you could use the SA-10 as a DAC via its digital inputs—saving you from buying a separate DAC.
    Final Verdict:
    If you primarily listen to stereo discs and digital sources, and want absolute reference-quality playback, the SA-10 is a worthy step up. If you mainly stream music, investing in a high-end streamer + DAC (like a Lumin, dCS, or Chord Hugo TT2) might give you more flexibility for the money.
    Do you primarily listen to physical media, or is streaming starting to take over? That might help fine-tune the decision.
