Advice speakers for 5.1.4
Mannion
Mannion Posts: 1
edited November 2024 in Speakers
Hi, I have a small 850 cubic feet bat cave and I would like to install a 5.1.4 system, which speakers do you recommend for LCR, surround and atmos on ceiling?
Thanks a lot
    F1nut Posts: 52,381
    What is the square footage, what is your budget and what will you use for power?
