Need help and history regarding these Polk's
Hi.. I've had a pair of 2nd hand Polk Monitor 11t speakers for about 10 yrs. Currently, the left speaker fails to sound unless I jostle my Yamaha receiver's volume control. Then it plays fine.
Today I decided to open them up and was surprised to see that they're 36 yrs old! Since I'm pretty fond of them, I'm thinking about replacing the caps and possibly the tweeters.
Would these be good ideas, considering their age?
Also, could someone tell me why I see the letters "RTA" in some online data reviews and specs? Thanks
    F1nut Posts: 52,381
    The issue is not your speaker, it's the volume potentiometer in your Yamaha.
    RTA stands for Real Time Alignment.
    Upgrading the caps and resistors is a very good idea. So is replacing the nasty SL2000 tweeters with the RD0194-1.
    Adding spikes that will pierce the carpet will help clean up the mids and improve the bass response.
  • jonwb12
    Hey thank you... Will look to do both. So these are not a RTA design, correct?
    pitdogg2 Posts: 27,881
    Not a true real time alignment as all the voice coils are not on the same plane.
  • boston1450
    boston1450 Posts: 7,758
    When posting questions on your speakers it may make it easier to identify them as RTA11t . It can be confusing, as it does say Monitor. There is a Monitor 11 speaker as well (they look more like a Monitor 10 speaker)..
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    Question . Can this crossover be upgraded to the TL (if someone is upgrading caps & resistors) to be able to use the RD 0198 tweeter ?
    Randy-Maine
    by David WMG
    F1nut Posts: 52,381
    boston1450 wrote: »
    Not sure, never looked into it.
  • jonwb12
    boston1450 wrote: »
    Well, it's confusing because nowhere on these speakers does it say RTA. If they're not truly "Real Time Aligned", why did Polk give them that name?
  • boston1450
    They are RTA11t's . Got me. I thought RTA was Real Time Array lol.. I have the RTA15tl's
    Randy-Maine
    by David WMG
  • stevep
    stevep Posts: 366
    edited November 2024
    boston1450 wrote: »
    I think you would be correct, at least that's what Polk's doc says.
  • boston1450
    The RTA series had the 8-11-15 tower cabinet speakers. Iirc they also had the RTA12 which was kinda like a Monitor 10 or 11 with crossovers on top - with a framed cloth hat (cover for crossovers)
    EDIT. there may be more I'm not aware of
    Randy-Maine
    by David WMG
  • boston1450
    stevep wrote: »
    boston1450 wrote: »
    I think you would be correct, at least that what Polk's doc says.
    Same idea.. I haven't seen my speaker boxes in forever. Polk didn't put much info out there & same with labels on cabinets. The Monitor 11 has a L & R sticker for Left & Right cabinet placement & they were known to fall off. I taped mine on & marked them :o
    Randy-Maine
    by David WMG
    F1nut Posts: 52,381
    boston1450 wrote: »
    Yep, you are correct. I got 2 out of 3...lol
  • Gardenstater
    Gardenstater Posts: 4,921
    They gave the marketing department excessive leeway on this one IMO lol. Should've called it the LSA Series maybe (Line Source Array). With the R.T.A. 12B they had the dots lol, in the instruction manual anyways.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • skrol
    skrol Posts: 3,493
    I think these go into some of the changes made to the TL vs the T.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Gardenstater
    boston1450 wrote: »
    Shouldn't be a problem because the t and tl crossovers are in the archives, but you have to change one inductor (what is DCR?), one capacitor, and one resistor, along with omission of one resistor.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • jonwb12
    jonwb12 Posts: 9
    Update: OK so I removed the 34uf capacitor from the crossover and it read 36.16uf using a Klein multimeter with capacitance testing... a little above its rating.
    I've decided that IF I change these out, I'm going to replace them with similar non-polar capacitors.
    Given that info, would you still recommend that I change these out due to their age? (36 yrs)
    nooshinjohn Posts: 26,138
    boston1450 wrote: »
    Do Better!!!🤣🤣🤣
  • Gardenstater
    jonwb12 wrote: »
    I think they are tolerance K which would be +/- 10% so they would still be in tolerance but do you have the ability to measure ESR (effective series resistance) and DF (dissipation factor)? Those both tend to increase with age, especially with electrolytics.
    Nobody, and I mean nobody, at this forum will recommend either keeping those in or replacing with anything other than polypropylene film caps. Nobody knows another person's budget situation however.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 52,381
    ^THIS^
  • jonwb12
    I don't have that ability.
    Is the recommendation for film caps based on "possible" better audio quality or longevity?
    Honestly, I'm 65 and I don't really need to give these a longer life than mine... :smile:
    Sonically, they still sound very good.
  • Gardenstater
    Don't say that about 65 🤣
    It is unanimous amongst audiophiles who don't have tin ears that polypropylene caps in crossovers sounds better than electrolytics. There will be measurement addicted people that may disagree but they probably also have tin ears and are relying on types of measurements that can't possibly measure what the ear/mind can.
    https://www.humblehomemadehifi.com/Cap.html
    https://www.humblehomemadehifi.com/download/Humble Homemade Hifi_Cap-Test-Ratings.pdf
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    audioluvr Posts: 6,065
    RTA stands for Real Time Alignment...
    Ya, I remember when my memory started failing. It was... Uh.
  • Schurkey
    Schurkey Posts: 2,126
    Even FRESH electrolytics are likely to sound better than ancient electrolytics. Electrolytics have a limited service life, and yours are way beyond what's expected.
    But as said...film caps are preferred. Even Polk used a film cap in a critical application--the big "Mexico" 12uF cap in that crossover pictured above.
    You can do better.
