Integrated Amp for LSi15
I recently bought a home and the old owner left their entire HT system behind: 2 LSi15s, 2 LSiFX, LSiC and PSW1000, all of this is being powered by a Denon AVR-3805. I plan on selling the LSiFX and LSiC as I will only ever use this setup for music and the room isn't huge. My question is whether or not the current receiver is adequate or if I should looking to getting a more powerful integrated amp. I'm a complete audio newby and want to keep the whole system simple so I am not interested in separate pre & power amps. I'm open to buying used, what would you recommend?
  • agingboomer
    Before you sell the surrounds, try setting the system to 5/7CH STEREO mode. You might appreciate the sound.
  • DaveHo
    DaveHo Posts: 3,584
    That'd be pushing the receiver's power supply to the max unless the volume is kept low. Those are 4ohm nominal.
  • agingboomer
    For what it's worth, here's a snippet from an Audioholics review from 2004:"The Denon AVR-3805 didn't appear to break a sweat driving the 4-ohm impedance presented by the RBH Sound 1266-LSEs and 661-LSE speakers. In fact, the rated 120 watts per channel was sufficient enough to drive the Reference 3 System speakers to a steady 97dB SPL at the listening position without any audible distortion."
  • skrol
    skrol Posts: 3,497
    The LSi15 is a hard to drive speaker with impedance dipping down around 2ohms at certain frequencies and need current, not just watts. Speaking from experience you could start out with that receiver but I think the LSi15 will benefit from an amplifier that can drive more current. I ran my LSi15's off an old but hefty Denon DRA-835. The bass just didn't have much impact even with the upgraded woofers. They came to life when I switch to a Parasound HCA-800ii and even more so with my HCA-1000A. The bass tightened up and the speakers just sound right (cohesive). I would consider these amps as low end Parasound but very capable. I hope to upgrade to an HCA-1200ii or HCA-1500 but the HCA-1000A is cutting it for now.
    I had similar experience with my LSi7s that I use in my office. I figured I could just use a receiver and a sub since I wasn't pushing them. They sounded like crap. Then I set the up with the HCA-800ii and they are wonderful.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skipshot12
    skipshot12 Posts: 2,167
    I’d buy a Krell FBI Integrated in a second if had the scratch.
    An integrated that will drive any speaker thrown at it.
    VR3 Posts: 29,756
    I would say this has always been an old conundrum for Polk speakers as they need high end equipment to really sound their best, sometimes exceeding their retail price
