Thiele Small parameters for PSW 202 driver
Hello,
I got the driver of a deceased subwoofer , the PSW 202 10 inch 4 ohm 50 watt. Apparently the amp failed. I saw a lot of messages about problems with the amp on this model.
Anyways, may be that is why the driver looks new and I would like to give it a second life.
I need to build an enclosure for it and have checked several tutorials and tried both WinISD and speakerbox little but I am missing the technical parameters to get the measurements right.
If I can get the data, I would like to build a ported enclosure. If not, may be I go for a sealed box.
I did my test with estimations provided by chatgpt but I don't know how close or far from the actual data they might be.
It's a 10 inch 4 ohm 50 w
And the estimates are
Fs: 30-35 Hz
Vas: 60-80 litres
Qts: 0.35-0.45
Qms: 5-7
Qes: 0.4-0.5
Sd: 330 cm²
Xmax: 6-8 mm
Re: 3.6-4.0 ohms
Any help would be great
Thanks,
Luis
Answers
    VR3 Posts: 29,731
    I'm just not sure the juice is worth the squeeze here?
    This was very entry level back in the day.
    When you build a subwoofer, arguably the last expensive part is the driver most instances.
    But the time you build the box and buy the amp... Could maybe just buy a known kit or orphaned svs, hsu, etc
    F1nut Posts: 52,381
    Definitely not worth investing a penny.
  • skrol
    skrol Posts: 3,493
    I don't have a lot of experience with subs but I've played around with a few Polk lower end subs. I even upgraded the amp in one replaced the driver with a 10" car sub in a PSW-10. They were meh ok. Then I fund an older entry level HSU STF-1 8" sub new old stock in a thrift store for $75. It is no contest. This thing is easy to blend with my LSi7 and sounds great. It could send me down the sub rabbit hole.
    Stan
    Main 2ch:
    HT:
    Other stuff:
