Question about RTA-11tl tweeters
Picked up a set of RTA-11tl's with the SL-3000 tweeters. Anyone know if these have ferrofluid? They sound like crap. Wondering if they do and may be the fluid is dried to gunk. Thanks!
  • VSAT88
    VSAT88 Posts: 1,379
    Finding that both MW in one cab were reverse wired and changing that helped a lot... Whats crazy is it looks as if it had always been that way.
    F1nut Posts: 52,305
    No ferrofluid.
  • boston1450
    boston1450 Posts: 7,758
    Congrats. Worth putting some RD0198's in them if your keep'n em
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • VSAT88
    VSAT88 Posts: 1,379
    $100.00 why not. Got SDA-SRS2's, RTA-8t's, SDA-CRS (TL), Lsi 15's and SDA2b's, can always take on another set of Polks. May well 198 em.
  • VSAT88
    VSAT88 Posts: 1,379
    Took one of the old SL 3000 tweeters apart. Burnt voice coil as expected. However there was ferrofluid in there.
    F1nut Posts: 52,305
    Well, I'll be
  • skrol
    skrol Posts: 3,488
    VSAT88 wrote: ยป
    I am not too surprised. One of the crossovers in my RTA11TL had one of the bypass caps losely attached (not soldered) to the one soldered to the board. I recall someone saying a lot of dope was involve in the assembly process of the speakers in that era.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • boston1450
    ^^^^ you could be on to something. I use to get sticky fingers from the hash pipe
    Randy-Maine
    by David WMG
    F1nut Posts: 52,305
    I seem to recall someone years ago asked Polk whether they had ferrofluid in them. The answer was no. Judging by the photos they definitely do.
  • VSAT88
    VSAT88 Posts: 1,379
    Yeah Jesse leave it to me to find and buy an "experimental" set of Polks. One cab with both MW reversed polarity and ferrofluid where there should be none. That is just so far. We will see more I am sure after I dig in to the crossovers. I think @boston1450 may well be right!
  • boston1450
    Easy fix's so far. Cross your fingers. How's the cabinets look & is all the woofs correct MWs ? That's always a bonus
    Randy-Maine
    by David WMG
    F1nut Posts: 52,305
    VSAT88 wrote: ยป
    The answer from whomever that was at Polk could easily be wrong.
    Maybe someone here has an SL3000 they'd be willing to take apart for a look see.
  • VSAT88
    VSAT88 Posts: 1,379
    Well I really like the RDO-198 tweet so will probably pick up a set to put in em. Far as the MW, yes. They are all factory correct MW 6510's. Information I would not have if it were not for this site and the people here so thanks to all for all of that. Are we still able to buy new tweeters from Polk or are we buying from a third party now like Mid West or god forbid eBay?
    F1nut Posts: 52,305
    Polk has them.
  • VSAT88
    VSAT88 Posts: 1,379
    Thanks brother.
  • skrol
    skrol Posts: 3,488
    This is from the RTA brochure.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    F1nut Posts: 52,305
    Thanks for that Stan.
  • VSAT88
    VSAT88 Posts: 1,379
    Yes Sir. They still got em in stock Made the order yesterday. Now all I need are crossover components. Think I have some Black Dragons in stock.
  • bcwsrt
    bcwsrt Posts: 2,648
    That literature still makes the 15TLs sound BA, just sayin'! ๐Ÿ˜๐Ÿ‘
    Brian
  • VSAT88
    VSAT88 Posts: 1,379
    bcwsrt wrote: ยป
    When I am done with them I hope they sound the same.
  • VSAT88
    VSAT88 Posts: 1,379
    edited November 2024
    198's arrived. Had to go ahead and put them in even though I have done nothing to the crossovers..yet . Good lord what an improvement getting those MW back in phase and these two tweeters made. The speakers are listenable now. Thank you all for your comments and help. I was very pleased to find that we may still order replacement tweeters for these speakers. They are like 30 years old now?
