Fosi Audio V3 Mono Power Amplifier
Irrenhaus
Hi,
Have not posted in some time. Just order a pair of these to give them a try. Is thru Amazon so 30 days to try them. I read some reviews that using a single 48V/10A power supply can introduce some noise. I will try first and then order a 2nd power supply to check the difference. They will be here tomorrow, but I will not have enough time to test them, I will be out the whole of next week in the field.
The Op Amps on the units can be upgraded.
https://fosiaudio.com/products/fosi-audio-v3-mono-power-amplifier
Cheers
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
Well finally last night I had some time to try the Fosi units and I have to say that I am impress. They drove the Linton's very nice with a nice punch on the low end. They do get hot and a little bit bright. I may try them on the R700 to see how they do.
I also got the speaker switch from Fosi. It is nice and you can have two sets of speakers and amplifiers and can switch between them with the remote.
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
I’ve read a bit about the potential noise issue with the single power supply too, so it sounds like a good plan to test it first and then try adding a second one. The ability to upgrade the op-amps is a cool feature as well. Hopefully, you get some time to test them soon after you’re back!
