Speaker question related to my post below
AllenLongcor
AllenLongcor Posts: 34
edited January 2002 in Technical/Setup
I'm still not sure whether to go with the RT55i or the RT800i's. Now I will probably not get to demo the RT55i's due to them not being in any store I know of here in Fresno. So my question is whether I should save myself $200 (a lot for a college student) and go with the 55i's. My system is:
CS400i center
Energey eXL:15 surrounds
Onkyo 595 receiver
etc...
With my system in mind should I go with the bookshelves or the towers? Decisions decisions. I also have a custom built subwoofer from acoustic-visions.com with a Shiva driver that kicks major ****, especially for my small room.
Post edited by AllenLongcor on
  • scottvamp
    scottvamp Posts: 3,277
    edited January 2002
    I believe they are basicly the same speaker but one is a tower and the other is a large bookshielf. I would think that the 800 would have a little more bass using the extra space in the tower.
    I would say save the money and get the 55's since you have an awesome sub. If you have a place to set them on. I think they have the same power rating.:cool:
  • scottvamp
    edited January 2002
    By the way good choice on the Onkyo595. How do you like it?:)
  • AllenLongcor
    edited January 2002
    I think it is great for my first real HT setup. I couldn't go all out and get a top of the line model. For the money I think this model is awesome. DD, DTS, and DPLII are all I could use or would want right now due to room limitations and speaker limitations. If money were not an issue I would get seperates or maybe a flagship receiver from a company and probably the new LSI series from Polk. I think my system with a great center and subwoofer is just perfect. I just need to replace those darn Eosone fronts and I'll be done. Maybe I'll replace the Energy surrounds with some more Polks but I proabably don't need to. I was also looking at the Pioneer VSX810S and 850S. I was swayed by some people away from it. It lacked DPLII but had a rear channel. In summation it is a superb entry level receiver.
  • AllenLongcor
    edited January 2002
    Ok the differences I see between the two are:
    Freq. response - RT800i's is 28Hz to 26kHZ, RT55i's is 35HZ to 26kHZ
    Lower dB limit - RT800i 42HZ, RT55i 47HZ
    Upper dB limit - RT800i 2kHZ, RT55i 25kHZ
    Efficiency - RT800i 90dB, RT55i 91dB
    These are the most important factors between the two. There is also some crossover stuff with the RT55i that I don't get at all. With my system (entry level) I think that the 55i's will work just as well as the 800i's and save me some cash. I may go with the 55i's based on the VERY similar specs and the lower price. I know that Ron P likes his very much. Now if someone would just give me some money I can order them tonight :D
  • juice21
    juice21 Posts: 1,866
    edited January 2002
    just remeber to add the price of good speaker stands into the price of the 55's. could add another $60-80. either way, i think you will be happy with whatever you go with (sounds like the 55i's), both great speaks for the price, and they will go great with you center and your 595...
  • TroyD
    TroyD Posts: 13,093
    edited January 2002
    good speaker stands ain't cheap...something to consider.
    Troy
  • AllenLongcor
    edited January 2002
    I have some stands that my mains are on right now that I will use. May not be the best in teh world, but they will do for my setup.
  • juice21
    edited January 2002
    kanicker posted that he got some 800i's at fry's electronics for $400 for the pair. don't know if these were open box, or if fry's even does open box items. i'm on the east coast, so i don't have any experience with fry's, but if the 800i's are $400, i would go with those, don't have to worry about stands, and they go a bit lower than the 55i's. check it out if you have a fry's near you....
