Mitsubishi LT-5V Vertical Turntable
SCompRacer
SCompRacer Posts: 9,147
edited October 2024 in DIY, Mods & Tweaks
The end of record/arm return-stop quit working on the Mitsubishi LT-5V. They used bulbs and photocells for operation. There is a plate with slots in it at top in front of arm bar. Light shines through and triggers stop though a small slot blocked by the bar.
The stop LED in the arm was bad. I had replaced all the bulbs with LED's a couple years ago. I verified the resistor choice put them below the 20mA max current. The other two LED's were still good. Oh well, al fixed now. Also replaced strobe LED's.
    EndersShadow Posts: 17,740
    Your on a role with audio repairs Rich!
  • jdjohn
    jdjohn Posts: 3,415
    Great work, and very interesting, since I always 'assumed' those Mitsubishi turntables were direct drive.
    edited October 2024
    Thanks! Same here! When I got it years ago, I saw the strobe and read they had PLL (phase-locked loop) and thought the same. It is really a nice sounding and great performing table. Folks that never knew vertical turntables existed are amazed by it.
  • agfrost
    agfrost Posts: 2,482
    edited October 2024
    Nice, Rich. So you're into Mitsubishi linear turntable repair, eh? B)
    Jay
    edited October 2024
    So far Jay.... :D
  • bikerboy
    bikerboy Posts: 1,236
    Great work Rich. Always wanted one of those
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
