Atrium 4 - Large gap between mount and speaker / also can't be used as bookshelf speakers?
I am about to pull the trigger on some Atrium 4's for my outdoor deck. They will be mounted vertical like a speaker would normally sit but I'm worried they are going to look funny because the bracket puts such a huge space between the speaker and back of the bracket. I've attached a photo but I am unsure if it will show up as I am new to using this forum.
Also, I am concerned if I want to use the speakers indoors later and bookshelf speakers they wont sit flat due to their round looking shape. Does anyone have any experience with that?
temp.png 221.1K
  • boston1450
    boston1450 Posts: 7,759
    Try them out at different angles. Your ears don't care what they look like. Mount em & enjoy
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
