Monitor 7B Question: - "Resonance" on this song track
odcics2
odcics2 Posts: 396
edited September 2024 in Vintage Speakers
Here's a song that I notice has some extra "resonance", at about the 1:55 second mark.
It sounds louder, a 'bump' in the volume best describes it.
McCartney - Hot as Sun / Glasses
https://www.youtube.com/watch?v=diL3AnFc3SM
"Glasses" is actually McCartney playing a set of drinking glasses...
For reference, I have another pair speakers that don't have this issue, at all.
I'm trying to figure where my problem could be on my 7B speakers.
Midwoofer? tweeter? crossover? (all parts are original)
I don't notice any other anomalies on any other recordings I play on these 7Bs.
Thanks for any insight you guys can offer.
    F1nut Posts: 52,406
    Obviously, it's in the recording. There's no problem with your speakers.
  • Gardenstater
    Gardenstater Posts: 4,991
    I didn't hear anything unusual on mine. The resonant peaks were at 473 Hz and 1.1 kHz if that helps you at all.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • odcics2
    odcics2 Posts: 396
    I have other speakers that don’t have the same anomaly, so it’s this pair of 7B specific.
  • odcics2
    odcics2 Posts: 396
    I have an extra pair of midwoofers that I could swap into my 7Bs.
    Any possibility that it’s a cabinet resonance at those frequencies, exciting by those two peaks?
  • Gardenstater
    If you plug the internal dimensions of the 7B into a standing wave calculator, you get that the main trouble spot is around 900 Hz. I did the testing again and actually did see peaks right around there, but they oscillate in and out.
    You don't have the BH5 behind the midwoofers, and you don't have the Armacell inside the basket so you could be getting an exaggerated effect from that as it passes through the cone diaphragm and bounces back and forth inside the basket, that I am not getting with mine. Also, do you have the roll of polyfill tucked up behind the midwoofer and tweeter?
    You also could be getting ringing of the stamped steel basket. You don't have Dynamat or other CLD material on the basket, correct?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • odcics2
    odcics2 Posts: 396
    I’ll double check the polyfill.
    It was located correctly when I checked them out after I bought them.
    The MW and passive have strips of a dynamat like material. I don’t remember the brand offhand
  • odcics2
    odcics2 Posts: 396
    I have No-Rez on order and will do a dowel brace, front to rear.
    xschop Posts: 5,932
    Smart move on the dowel brace. I'd also add to double-check the tightness of the tweeter magnet screws.
  • odcics2
    odcics2 Posts: 396
    Will do.
