Onkyo DX-C390 CD Player
Seggy
Seggy Posts: 22
edited June 2004 in Electronics
I'm thinking of replacing my 20 year old Sony CD player and I've been looking into the Onkyo DX-C390 player/changer.
Any opinions?
Thanks, Mike.
Post edited by Seggy on
    F1nut Posts: 51,712
    edited June 2004
    What's your budget?
  • Seggy
    Seggy Posts: 22
    edited June 2004
    $100.00 - $350.00
  • shack
    shack Posts: 11,154
    edited June 2004
    The Onkyo appears to be a decent changer...
    If you are sold on the idea of a changer (which I am) you might also want to consider the Sony CDP-CA70ES. Solidly built Sony ES (5 yr warranty) with very good sound. Oade Brothers has them for around $225.
    The Denon DCM-380 also has decent sound quality for about the same price. The build quality might not be as good as the Sony.
  • woodyjacobs
    woodyjacobs Posts: 706
    edited June 2004
    Hey there,
    I have the previous model, the dx-c380. I have found it to be a solid performer. Good sound quality, quiet operation. I have tried out a few CD changers over the last couple of years (Denon DCM-370, Yamaha cdx-506) and I like this one the best. The Denon had good sound quality but was noisy as hell when changing discs, and had trouble with discs that were a bit scratched up (that the Onkyo played fine)...the Yammie worked fine but I like the 6 disc capacity of the Onkyo.
    I bought mine refurbed off of Ubid.com about a year and a half ago and have had no issues with it at all. Of course it doesn't get much use as my main system has one of the Sony 300 disc mega-changers. In fact I'm not using it at all right now. I'm not trying to hijack your thread to sell mine...but if you have any interest let me know.
    In any event, if the new model is as solid as the old one, I would think you will be happy with it.
    system 1:
    Athena: AS-F1 mains, AS-C1 center, AS-B1 surrounds, AS-P400 sub, Yammie RXV-730, Rotel RB-976 driving front stage, Samsung BD3600 Blue Ray, Denon DVD2900 for sacd/cd , jbl n24awII on the deck, samsung 40" 1080p lcd
    system 2:
    XBox 360 Spherex 5.1 system, HK DVD38, Phillips CDC 926 CD changer, Phillips 32" LCD
    2 channel
    NAD 1600 pre, NAD 2400 THX amp, Phillips CDC 926, Linn extra speaks, crappy TT
  • arufener
    arufener Posts: 63
    edited June 2004
    You might consider H/K DVD and CD players
    Sooner or later you're going to realize, just as I did, there's a difference between knowing the path...and walking it.
  • Seggy
    Seggy Posts: 22
    edited June 2004
    Thanks guys.
    I'm going with the Onkyo. (The latest model, thanks anyway, Woody.)
    Great forum as always.
