New build main wall for built-in; V85's or 265-LS- mostly music with occasional movies
Torn between 3 V85's for my main channels (with 2 subwoofers) or the LS series which is more home theater based...90% of our powering is for music, not for movies. Thoughts?2iagh7hzt0q3.png
    billbillw Posts: 8,373
    I wouldn't say the LS series is more for home theater. That would be the RT series. The LS has the ring radiator tweeter, which is a big step up for clarity and imaging. That might be appreciated for music, if you are sitting and really listening. If you are just trying to fill the room with good sounding background music, then the LS might not be worth cost upgrade.
