Sub box dimensions
Systems
Systems Posts: 14,873
edited June 2004 in Car Subwoofer Talk
I have a signle MM2104 (I think that's it. 10" 4 ohm MoMo). I want to build the exact box that Polk reccomends (.66 cu. ft. sealed). In the box plans area all it really gives you is outside dimensions, and I was wondering if anyone can help me figure out what sizes I need to cut each board (top, bottom, front, back, left, right) when using 3/4" MDF to get the right dimensions? I know that if I figure it out I'll wind up making it too small and the sub won't fit. They say these dimensions:
Overall External Dimensions
Width 15" (38.10cm)
Height 13" (33.02cm)
Depth 9-141/250" (24.29cm)
Thanks for any help.
Testing
Testing
Testing
