Center Speaker for Monitor 7Bs, 10As
I am rebuilding / Modding some 7Bs and have 10As that I would like to get a Center speaker that would closely match them. Any suggestions, Polk, others? Also thinking about possibly building a speaker for it. Suggestions? I have a 5B but it is too big and not right. I don't need full range just upper bass to treble for voice, instrument depth and fill when playing 5 channel as most normal center speakers do. I do play 2 channel also with the 10As and soon 7s.
  • joebass3
    joebass3 Posts: 311
    edited August 2024
    I like the CS350-LS.
  • boston1450
    boston1450 Posts: 7,758
    ^^^ +1 . Also Cs400 or Cs400i. You could go Cs1000p with the 2 subwoofers also. I have had/have all these & they are all very good subwoofers of Polks Monitor line
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Sumbrada69
    I ordered a CS350-ls off EBay. Now we will see how it comes and sounds. Thanks for your suggestions.
  • Sumbrada69
    Got got the Cs350s today. Great packing, good thing. They are in great shape. Hooked them up and WOW what a difference. Major upgrade. I'll play them some then do the Cap upgrade. Not sure if a resistor is there. I'll replace it if so when i get 1. Thanks for the great suggestion.
    F1nut Posts: 52,382
    Guaranteed you will find resistors in there.
